Just so you realize that Moe's stern is bigger than my stern. Wait a second, is a bigger stern better??? Size matters.Randy Smith wrote:UH, Moe, Randy....Darn nice sterns you boys got!!![]()
Randy
Naive Aussie seeking US wisdom
- RandyMoon
- Location: Rockwall, TX Lake Ray Hubbard 2005M #0690 L405 Tohatsu TLDI 90 (Rhapsody in Blue)
Re: Moe and Randy
Click for a MacGregor 26X and 26M Comparison
What amazes me is how MacGregor gave up the X's great "back porch" on the wide transom by moving the M's helm seat back, and still wound up with a smaller cockpit, and no more room in the cabin that I see. Look at their own cabin layout drawings on the web page above.
Since the conversation got a little OT about outboards...
I own both a Suzuki DF50 and a Merc BigFoot 60. The Suzuki is a little 815cc 3-cylinder double overhead cam four-valve per cylinder 40 HP outboard overreved to 6,500 rpm to get 50HP with its lower torque. The Merc is a larger 996cc 4-cylinder single overhead cam, two valve per cylinder 60HP outboard, you can get in a 50HP version.
It's like the difference between a small high-tech hopped up V6 and a bigger V8 engine. While the little motor's fine in a small go-fast vehicle, I'd rather have the V8 in a big truck... and that's what the Mac is like. The Merc can also turn a larger diameter prop, which helps when pushing a barge like the Mac.
The Merc may be taller, but it's not really any wider than the Suzuki and that's what counts in the M's narrow transom opening. For narrowness, you can't beat a two-stroke like the Tohatsu TLDI and Evinrude E-TEC.
While the Suzuki's timing chain may outlast the Merc's cam belt, Step 1 of replacing the timing chain is to strip everything off the powerhead and completely remove it from the outboard. All you have to pull to replace the Merc's timing belt is the flywheel.
Finally, I can get parts for the Merc at several shops in town. The two nearest Suzuki dealers are 60 and 300 miles away and I wind up using mail-order.
- aya16
THUNDERDOME, THUNDERDOME, THUNDERDOME,THUNDERDOME
Two boats in one boat out. X V M what boat is better.
If the only choice I had was the X over the other boats on the market I would buy one. But sadly I think some here think the M is not up to snuff.
That beautiful white-hulled thing I receive so much pleasure on is second rate, a mistake some here would not even give it a passable glance as
It has so much wrong with it. Ahh but I dont care, I bought one anyway
and put second rate autopilot and second rate lowrance products on it.
Mickey Mouse lines led aft and propane stove in the cabin. And anyone dare mention they like the M over the X would be made to go sit at the childrens table of life. I shudder, I only launch at night so no one will see my mistake, I painted the top black stripe white so I could pass as an X. I dont let anyone in the cabin for fear they will know its an M. When I sail near an X I avoid the skippers eyes in shame. I put seawater in my ballast tank instead of sparkletts, I use black docking lines instead of gold.
When I post about my mate shes a mate and not good enough to be an admiral. If I only bought a used X I could avoid all this shame. Sorry I like the M better so shoot me. Thunderdome,
She is faster then an X
- baldbaby2000
My wife and I bought an 2005 M last fall and have used it a lot and love it. I've been on an X but never sailed on one so I can't comment on performance. I like both boat's interiors for different reasons. I think the M needs some ballast low on the dagger board to reduce healing and I assume the X could use also some weight on it's swing keel. Given that assumption, I would go with the M because I think there are more options for adding ballast to the board. There's been a lot of discussion on this if you care to do a search.
BB
BB
