(1) I have no bottom paint at all, no barrier coat, zip, zero.... how urgent is the need to barrier and anti-foul the hull before i see problems.?
The amount of sailing i can get in will increase HUGELY, not having the hitch,tow,rig and launch process in front of every outing. I will be able to sail after work for a few hours, have people meet me at the boat and leave immediately for excursions, etc. These seem to me now a luxury, and the reason i bought the boat to begin with. But the commercial bottom job with barrier coats etc. will factor in at near half again the cost of the slip per month (130) and the alternative is for me to paint it myself.
(2) Also, i presently have a bilge pump, not attached, no float switch, just loose for occasional bailing, seldom necesary, but if slipped in the water for extended time, i would need to rig an attached, float switched pump set-up. Since there are actually several isolated bilges, due to the integral ballast tank, I wonder if there is a optimal location, maybe the deepest one, which would collect the other bilge overflows and keep the boat from swamping, even if the other bilge areas did have water up to their limit ? Seems a bit of overkill to have numerous pumps, although maybe a back-up would be good in one other bilge area.
