Thanks @Be FreeBe Free wrote: ↑Tue Sep 09, 2025 5:38 pm Mold and mildew are pretty common where I live. The key is prevention but that's easier said than done. Humidity is a fact of life here and and I've not found anything that is practical for the boat to keep it down year-round. Chemicals (calcium chloride) quickly get overwhelmed and anything that uses electricity is not feasible away from shore power. The only thing that works is to keep the surfaces wiped down with disinfectant (bleach) wipes so that the spores don't get a chance to grow.
For small areas like the interior of the cabin I've found that any cleaning product with "bleach" does a good job of removing it and slowing down the growth. If you have a large area to treat you can mix household bleach and water 30:1 to make an effective cleaner.
I don't use vinegar (acetic acid) for cleaning anything other than calcium deposits but it will be effective on mold as well. The smell and the fact that it can get expensive if you have a large area to treat are the main reason I usually go with sodium hypochlorite.
I also live in a soggy mess. Mold and mildew will grow on you if you don't move faster than a turtle!
I don't have an issue w interiors as I keep dehumidifiers in the boat.
This'd be why I love bleach for the outside. Even under a dry RV shed (gravel gets dusty its so dry), things get nasty quick and power washing is insufficient. I used bleach straight this year. I forgot to dilute. Works quick though!
Whos tried borax? It appears safe on everything boat related and is a mold/mildew inhibitor. Does it work on removing the stains in gelcoat line bleach does?
Here's something I dug up using gpt I might try next year instead of bleach:
1/2 cup oxygen bleach powder
1/4 cup Borax
1 gallon warm water (100–120°F)
2 tablespoons Dawn (blue original)
Seems to be much more mild than bleach and safe for everything. Will probably up the of concentration of everything x2 if that doesn't work fast enough...
I've tried everything on the cockpit cussions except bleach... Getting disheartened that anything really works beside bleach...
