Hi Larryd97!
Sounds like there are a few things “cosmetic” and a few “like to haves” and a few “serious” items on your list.
Might I suggest first getting a gallon of elbow grease if you decide to keep her as this makes the process go a lot smoother.
Also engagement by your family before making a decision either way.
Making it a family decision might reduce some of the stress and angst hopefully.
I can’t/won’t say one path or the other is best for you… your boat/your rules.
If keeping I’d pare down the list on a few points…. These are just my opinions not gospel…
- the floor mats => I’d simply remove them now and toss them in the trash… they are obviously trash… just pitch them and move on
- blown main sail => I’d simply toss it… a sun bleached weakened torn failing main sail is a hazard… if it rips out under load it’s a hazard to you, you passengers and others around you on the water… you just don’t need to deal with that hazard because sure enough serendipity has given already given you a heads-up about the problem… repair isn’t really an option once the fabric ages out… at a later point in time you can replace it with another one (new or gently used) …. just pitch it and move on
- leaking fuel tank when heeling => Pull it out and find out where it is actually leaking… is it a fuel cap? The cap can be easily replaced… is it the engine fuel line fitting? It can be easily tighten or sealed…. Is it the fuel line clamp? It can be tightened…. Is it the fuel line? It can be easily replaced… is I a crack or wear spot in the actual fuel tank? Then appropriately drain it / flush it / air it out throughly and THROW IT OUT… there is in my opinion no valid or permanent effective appropriate way to repair a cracked or worn polypropylene fuel tank… just toss it and move on
- interior cushions in rough shape smelly mold => Are they torn? Failed seams? Stained/discolored? …. Now you have to make a choice…
—- If they are structurally sound might I suggest that you ….Take them out, lay them out on the driveway, spray them throughly with a 10-15% bleach solution on both sides, let sit for 20-30 minutes then rinse throughly with fresh water , rig a rope and hang them up to drain in the sun for a couple hours…. Then unzip them and carefully pull the foam out… let the covers continue to dry and air. Get a clean kiddie pool to throughly hand wash out the foam cores with a 10-15% bleach & laundry soap & laundry sanitizer liquid then throughly rinse out with lots of fresh water… hang up to drain and dry… Now take the covers and do the same… when very throughly dried spray everything with a couple cans of Lysol… let dry again then reassemble … yes the wash water will probably be black (ours were) and it will be a bit of work but our OEM cushions did clean up nicely and nearly all the stains/discoloration disappeared entirely. I’d AVOID the temptation to machine wash and do it by hand.
—— If they are not structurally sound or it’s not worth the hassle in your situation then simply toss them for now and get them out of the way… replacement can be a later purchase our DIY project
—- Note: We did both! The cleanup (and really enjoyed the results) AND we later chose to make a new interior layout and new cushions as part of that project.
- The auto-pilot is DOA … If it’s dead it’s dead… it’s not a necessary item.. it’s a limited use convenience for most folks.. remove and toss it or ignore it as it doesn’t matter for 99% of boating… you really don’t need to replace it or fuss with it… get rid of it and move on
- The Raymarine GPS is dead… if it’s dead it’s dead.. it’s not serviceable, just toss it… you can get an app on your phone or tablet like Navionics or other similar apps… or you can replace it at a later date with a new or gently used GPS … you don’t need much to use your boat … I actually use and carry a current paper/plastic map for the waters we navigate… just toss it and move on
- Bimini issues …. That just something to do… we all have had to do that at some point… you can get replacement straps or you can rig with new lines… not a difficult project… move forward
- interior smells possibly because of leaks …. Now that you have all the cushions out open up and remove all the interior covers and dry out the boat and bilges… a cheap WET/DRY Vacuum comes in handy for a lot of things… We have a little 1 gallon one that we use for lots of jobs in the boat, car, house & garage…remove or suck out any accumulated water… ventilate the interior with a fan … wear a mask if you find any mold or mildew… then spray everything with a 10-15% bleach solution and allow to dry… as you have a Mac26M with the wall carpeting I’d suggest you consider the Rent or buy a good hand steam cleaner vacuum and work your way through the boat with it and maintain good ventilation… yup it’s a bit of elbow grease… but well worth it to refresh things… personally we annually do a complete wipe down of our Mac26X with a 10-15% bleach solution and it makes it really nice for the season’s use… move forward
- leaks …. Fixing the window seals is a job but shouldn’t be a technically difficult one … it takes two people and some time.. to limit your efforts take some paper towels or TP and tape around the perimeters of the windows then hose down the exterior of the boat
a window at a time with a garden hose while someone is on the inside to check & record when/wear any water leaks occur…. Address this windows first… personally I’d recommend that you use butyl ribbon caulk witch is available at places like HomeDepot (it’s one of the best sealants if done properly and is also easily adjusted and/or removable in the future… I’ve had to remove other sealants as they have repeatedly failed .. especially AVOID ANY SILICONE SEALANTS as they fail in marine environments and are a genuine PITA to deal with/ apply / cleanup … fix the one(s) that leak … move forward
- gel coat issues - generally a good wash helps a lot… this is a preference thing that is very individualistic … appearances are something you have to decide… the reality is some want a shiny new look and others could care less… I know folks who spend all their time prepping/waxing/polishing their car/boat/plane/motorcycle (or whatever) and never seem to actually use or enjoy using their toy… kind of a balance of life thing you have to decide for yourself… personally we spray down with a 10-15% bleach solution, allow it to sit for 10-15 minutes then lightly power wash from about 18 to 24 inches above surface (never closer!). We use the local DIY hand car wash most times as it’s there and all the soap/water/spray/brush stuff is all there (and the mess)… this is typically a 1-2 hour project… No our boat isn’t pristine but we also know it’s 20+ years old… but it’s clean and we really prefer to enjoy the using of our boat rather than having it as “an image” item… this is a ‘to each to their own item… move forward
- power connector at base of mast - … Are you sailing at night? Are you mooring at night? If not then this isn’t a significant item… move forward … If you are then it is something to deal with… the mast base connector on our Mac26X and wiring are accessible from the interior cabin ceiling via a couple of removable plastic cover disks … the OEM type replacement can be found from several sources but personally I’d suggest contacting BlueWater Yacht (the phone number is in the resource center I believe… not a complicated project that can be done in an hour or two with hand tools in most cases… move forward
- Fiberglass soft spots and repairs —- First question is are they reall blisters or delaminated paint build up? Check before you get too excited on this one as I’ve personally found that 8 out of 10 cases I’ve been involved with were not in fact fiberglass blistering but actually just delaminated paint (probably caused by a crappy cleanup prior to the initial bottom paint dirty application & without a barrier epoxy primer coat… check first by getting a putty knife/spatula and scrape at it to gently remove the paint and see what you actually have.
=> IF it’s just bad paint then that’s one thing and then it’s a simpler strip/epoxy-prime/bottom-paint project… simpler but not simple… IF you want to proceed with that sort of project then it’s a bit involved and would need a separate more in-depth discussion
=> IF it’s actually a Intra fiberglass blister then it can be repaired… it not too difficult and doesn’t need specialized tools of skills.. basic hand & simple power tools like pad sander… it’s a half day or so project type and is better discuss separately… move forward
- broken brake lines and leaking brake cylinder - Ok, this is a more serious issue… if you don’t have the mechanical skills it’s best to get this done by a professional with more experience, skills, tools and facilities… not insurmountable or generally too expensive… depending on what the actual particulars of the situation involved and what is found during the actual disassembly and work… ‘generally’ what you have described is a matter of time and neglect and there may be additional things that need to be addressed as part of the process so expect them and deal with them … brakes are critical to you, your family and a myriad of others surrounding you as you travel… yeah, it’s gonna cost but it’s something that can be accomplished … do it right … move forward
- crapped out engine - that’s a bummer fer sure… we’ve sorta been there/done that/got the T-shirt … while we chose to get a new Suzuki DF60AV for our extended cruising use that isn’t the appropriate answer for everyone… there are good used low hour engines out there for substantially less than the cost of a new engine… there are always people out there are people upgrade to larger engines… the Mac26M was designed for a max of 50-60 hp (although some have installed larger) so I’d suggest staying in that max power range to minimize costs…. If you are not cruising long distances there are going to be a variety of 2-strokes that can fit the bill… there are also going to be a variety of 4-strokes as well… don’t exclude dealerships as they are generally going to be a prime source of the good engines removed for power upgrades… they are also generally going to have the experience, skills, tools, facilities and parts needed to do a proper job in the least amount of time/hassle… this is something you can work on and get accomplished with a bit of effort and planning…. I’d suggest getting the other stuff above moving forward while you work on this aspect to get it accomplished within your budget and particular desires.
That’s enough for now as my typing finger is about worn out…
Hope this might be useful to you as you work through your process and decisions.
Best Regards
Over Easy
