Good to know. I was going for what looked like a straight run. Plug to plug might have been a way for me to make it work. I'll have to give it a go again sometime.Be Free wrote: ↑Fri Apr 11, 2025 11:31 am Russ,
I had the same experience hitting stuff in the ceiling. Places that looked like they should be a straight shot sometimes had stuff in the way. I just kept trying different routes until I found one that gave me a (reasonably) straight pull for the wire I was running.
Sometimes it involved pulling out some of the plugs and running straight from one to the other. The whole run might not be straight but it was straight between access points allowing the wire to be pulled easily.
Wiring Up an Anchor Light on the 26M
Re: Wiring Up an Anchor Light on the 26M
Wow, you do nice work. Waterproofing the diodes. Extra nice.
- Be Free
I learned that trick many years ago from someone who was running data cabling through a drop-ceiling.Russ wrote: ↑Sat Apr 12, 2025 6:07 amGood to know. I was going for what looked like a straight run. Plug to plug might have been a way for me to make it work. I'll have to give it a go again sometime.Be Free wrote: ↑Fri Apr 11, 2025 11:31 am Russ,
Bill
2001 26X Simple Interest
Honda BF40D
Honda BF40D
