Replacing "Macgregor 26" sticker on plate.
Does anybody know if there is a nut on the back of the screws that I need to get access to? I want to take the oval plate off to clean the old sticker off and put on a new one. 2006 26M.
- kmclemore
Re: Replacing "Macgregor 26" sticker on plate.
I always thought the whole thing was stuck on with double-sided tape. No?
I took the slow easy way.
After twenty years, both emblems fell off, leaving blank plexi ovals. When we get home, I now need to order from BWY.
It's a piece of Lexan and glued and screwed. I used a heat gun to melt the glue and it came off after the screws were removed.
Glued and screwed? That sounds like more trouble than it’s worth. I think I will do it in place.
Thanks for the information. You saved me a lot of trouble.
Isn’t there some sort of solvent, or a hair dryer you can use to remove the decal.
Have you tried emailing Todd from BWY for hints at removing the decal?
Great idea.
Heat is the secret.
I bought a cheap heat gun from Harbor Freight. I use that tool so much.
When I removed the plate, I still had to use the heat gun to remove the decal. I suppose I could have done it in place.
- Brian
- Location: Austin, TX 2006 26M "Soñador" white hull MACM0852G506 TLDI 90
My 2006 26M had a MacGregor 26 sticker on the black plastic oval that faded away after ten years in the hot Texas sun. I did not remove the black plastic oval from the boat. If I recall it was relatively easy to remove the old sticker. I did not even need to get out my heat gun. Just a razor blade and a quick wipe with Acetone.
This video from Practical Sailor shows an easy way to remove vinyl stickers from a boat.
Removing Vinyl Stickers From A Boat
Here are the links from Amazon for the Eraser Wheel and Plastic Razor Blade Scraper.
I had vinyl lettering with my boat's name made at boatus.com back in 2015. I don't recall the exact price, but I think it was less than the $23.50 that bwyachts.com charges for a replacement. The picture below was taken with my iPhone about five minutes ago. The lettering is getting a bit worn after nine years so I should probably order replacement lettering.
MACGREGOR LOGO, OVAL NAME PLATE
Ixneigh was going to have a stainless steel oval made which would be a more permanent solution.
Code: Select all
https://www.youtube.com/watch?v=SbOLMyiTuZ4Code: Select all
https://www.amazon.com/dp/B00FJF0O2K?ref=ppx_yo2ov_dt_b_product_details&th=1Code: Select all
https://www.amazon.com/dp/B076BBW1WM?ref=ppx_yo2ov_dt_b_product_details&th=1
Code: Select all
https://shop.bwyachts.com/product-p/h604-1m0.htmCode: Select all
https://www.macgregorsailors.com/forum/viewtopic.php?f=9&t=238392006 26M "Soñador" white hull MACM0852G506
TLDI 90
TLDI 90
- Jimmyt
Any folks interested in this topic may want to see these posts. Note, however, that the price has gone up since 2021…
viewtopic.php?p=352702#p352702
