Thanks! We are sailors at heart and still able to sail but are in our 70’s and having the ability to use theris wrote: ↑Fri Mar 24, 2023 12:03 pm As others have said "Welcome". We put our transducer on the stern (starboard side). We do not like the idea of drilling a large hole below the water line on a Mac. We do not even have a small hole below the water line. Because of disabilities we use the Mac as a trawler. This is a great forum, lot of Mac knowhow is found here. Enjoy your boat!
Richard
new 26X owners.
Re: new 26X owners
Re: new 26X owners.
Planning on posting write ups and photos of whatever I wind up doing on the boat. We enjoy reading your posts.
We went on the road 8 years ago in our Motorcoach from Bucks County PA. Doylestown area. Since then we have been to just about every state and every National Park. Found this place in Newport Oregon and loved it enough to purchase an RV lot to park the Coach and a slip at the local marina to park the boat. So we are planning on staying here for the foreseeable future.
Re: new 26X owners.
Doylestown, Pa to Newport, OR; quite a haul.
We look forward to seeing your adventures.
As to being in your 70's..............there are many of us.
- pitchpolehobie
Re: new 26X owners.
Thats a haul for sure! The 26x is an easy boat to learn all around. I think you can figure it out in a few hours and take at least a few years or more to perfect things.
What sailing experience do you have?
2002 MacGregor 26X: Remedium
Tohatsu 25HP
Tohatsu 25HP
- Jimmyt
Re: new 26X owners.
This is what I did. I have had some trouble getting it to read at speeds over 1 knot without having it deep enough to throw a wake when planing. Mine has no moving parts though. I just adhered a mounting block to the hull. Scuffed the gelcoat and smeared on a little 5200.SandZ wrote: ↑Fri Mar 24, 2023 8:15 pm I agree, would rather not drill a hole, the triducer is part of the whole autopilot computer input, giving speed through the water, water temp and depth, and being B&G was expensive, but I can find a stern mount that is compatible.
Or I will make a mount for the triducer I have and hang it off the stern. Might work!
viewtopic.php?p=346654#p346654
Re: new 26X owners.
Zoe has owned and lived on keelboats in New Jersey, and has sailed Long Island Sound and RI as well as the Jersey Shore waters. I grew up sailing scows on the lakes in Madison WI ( and ice boats in winter). I also had a Newport 28 at Herrington Harbor North for a while (Chesapeake). We currently own an Ericson 32 that we have not yet sailed, in middle of refit. We will be selling the Ericson most likely. Now the 26x will be a new experience for both of us.pitchpolehobie wrote: ↑Sun Mar 26, 2023 6:45 pm Thats a haul for sure! The 26x is an easy boat to learn all around. I think you can figure it out in a few hours and take at least a few years or more to perfect things.
- Jimmyt
Re: new 26X owners.
Yes it will!SandZ wrote: ↑Mon Mar 27, 2023 8:40 am Zoe has owned and lived on keelboats in New Jersey, and has sailed Long Island Sound and RI as well as the Jersey Shore waters. I grew up sailing scows on the lakes in Madison WI ( and ice boats in winter). I also had a Newport 28 at Herrington Harbor North for a while (Chesapeake). We currently own an Ericson 32 that we have not yet sailed, in middle of refit. We will be selling the Ericson most likely. Now the 26x will be a new experience for both of us.
- pitchpolehobie
Re: new 26X owners.
I think you have an excdllent foundation. Its a smaller and more tender boat than the heavy keelboats but in that way also sails a bit like a dinghy with a wheel. DEFINITELY, When the wind is "low" her high freeboard and minimal draft can be a dog. But once wind speed is up above 10 she handles so well and truly settles into a nice 15deg heel. I hope you both have a great start!Jimmyt wrote: ↑Mon Mar 27, 2023 3:41 pmYes it will!SandZ wrote: ↑Mon Mar 27, 2023 8:40 am Zoe has owned and lived on keelboats in New Jersey, and has sailed Long Island Sound and RI as well as the Jersey Shore waters. I grew up sailing scows on the lakes in Madison WI ( and ice boats in winter). I also had a Newport 28 at Herrington Harbor North for a while (Chesapeake). We currently own an Ericson 32 that we have not yet sailed, in middle of refit. We will be selling the Ericson most likely. Now the 26x will be a new experience for both of us.A water ballasted trailer sailer will definitely be a transition. Once you get used to the heeling characteristics, I think you'll find it enjoyable, though.
Tohatsu 25HP
Tohatsu 25HP
Re: new 26X owners.
Coming from keelboats, the initial tenderness of a water ballasted boat took some adjusting.
The admiral was especially sensitive to how light the Mac is and heels quickly at first. But it stiffens up and sails well at that point.
Re: new 26X owners.
I know Zoe will be able to adapt, although I’m sure the tenderness will take some time to get used to. I think my background of sailing m-20s and e-scows, and a few Lightnings, and quite a bit of windsurfing will help me feel at home and confident on the
Re: new 26X owners.
Keep in mind the Mac 26X/M are hybrid boats. Built as powersailors they perform poorly at both sailing and motoring.
With that said, the 26X/M can be a lot of fun to sail if you are not racing, like in a Lightning. It's a compromise boat with regard to performance. However, there is no other trailer sailboat like it for comfort and I think overall safety.
socalmacer
Re: new 26X owners.
Welcome!
As an original 1996 Mac26X owner, I have been using transom mounted transducers for 15+ years now. Not only good for speed but also water temp in addition to depth, fish finder, etc. Never a problem with leaks either - be sure to use stainless steel screws and plenty of silicone when mounting.
. I run the cable along the steering cable so no new holes to drill too. Good luck and enjoy your new
