Tohatsu prop size
- Ken Orthner
Tohatsu prop size
After sailing my 26X for almost 2 years - I finally had the opportunity/reason to run the boat for a long distance under power without interference. At WOT - it was showing 7000 RPM (a tad high perhaps?) the top speed was only 11 kn (GPS) - light tail wind - boat only lightly loaded - mast up - no ballast. Any of you "Tohatsu/Nissan motor owners that have played with the props - any idea what I should be running? I'm not sure what size prop is on it now - will definatly be taking a closer look this weekend
thanks
- kmclemore
Re: Tohatsu prop size
I thought the red-line on a Tohatsu 50 was 5500 rpm? I get about 17 mph at 5500 on my M50D... boat lightly loaded, 4 souls on board. My prop is 11" diameter, 10 pitch - I think it's a BWY custom prop - it has no markings on it.Ken Orthner wrote:After sailing my 26X for almost 2 years - I finally had the opportunity/reason to run king a closer look this weekend
thanks
- Bill Millar
Tohatsu Prop
My new Tohatsu 50LDI was delivered with an 11.1 x 13 prop. I couldn't get above 4500 rpm with this on my 26X, so changed to 11.6 x 11 and this gives 5,000+ rpm.
Have a look at this website
http://www.tohatsu.com/tech_info/prop.html
which might help.
which might help.
- parrothead
