A friend of my father-in-law has an 8/9/10 hp motor he might be open to selling. Hoping to to connect with him this week. He also owned a Mac 25 so I hope he can give me some launch and rigging advice.
Here are some more pictures of the inside!
Ant
Great advice on the testing of the coupler. Thanks.Jimmyt wrote: โWed Jul 27, 2022 4:41 am Take a small hammer and tap on the trailer (usually the bottom face of the square tube, or tongue, is the first to go). It should ring when you hit it. If it sounds dead, or the hammer goes through it, that's a problem.
Visual exam of the coupler is probably sufficient. If it hasn't lost a lot of material, it's likely good to go....
just verify that you can raise it a couple of inches above static above static height (static height when the trailer isn't coupled).
aprangley wrote: โTue Sep 27, 2022 4:00 pm Hi All
Just an update. I took most of your advice (new tires, checked the grease, checked the bearings, heat, checked the trailer for corrosion etc).
I rented a u-haul for a stronger first tow and it is not at my parents-in-law who have a big yard.
I am getting her out on the water tomorrow.
I could not have done it without all your advice!
Ant
