The M boat is a GOOD sailboat IN THE FRONT:
The lines on the forward part of the hull are quite classic and if you sail the boat on the bow like it's supposed to be sailed it's just as good as any other small boat.
Yes I agree the way the hull / deck joint flares up from the mast towards the bow gives the bow a nice majestic clasic curve as the bow/deck raises giving it that nice deep bow look , also give some extra head room in the V berth .
With my double anchor roller , two anchors & a big deep cycle anchor winch battery that also doubles as a second house battery all that extra weight helps in reducing some stern drag also I replaced my steering cable when it got to the point of 6" free play on either side of center with a the high performance one from BWY now zero play !
the straight hull/deck joints really take away the gracefulness of the flared curved one as the bow raises going forward
Oh & moving as much weight aft to raise the bow just doe,s not cut it !
Now what's more majestic than this
