Trying to make a flat floor was an exercise in patience for me. After 3 failed attempts to match the profile of the hull this is what I came up with. I knew what length I wanted across the beam. I cut a 1x4 at 52". Then I cut strips of some old luan I had at 1.5" wide and then cut them in lengths of 2",4', 6"& 8". These strips I hot glued to the 1x4 to give me the profile that I then traced out on some 3/4" plywood. I cut my plywood stringer out and then hopped in the lazarette with a sander and fine tuned the fit until I was happy or lost feeling in my legs from the cramped quarters.
I then screwed 2 pvc board spacers to the fore side of the plywood stringer. One the aft side I also screwed 2 for and aft longitudinal stringers and then squared it off with another board across the beam. The longitudinal stringers were cut short so the unit could fit in through the lazarette opening.
I then made a corresponding unit to fit the rear of the lazarette and mate up with the first.
Here they both are out of the boat....
I used stainless screws and counter sunk them. I then added a fillet of the structural repair putty to any of the inside corners that I could. I then used sections of 1708 tape and glassed over them. I also saturated the plywood in resin to give it more water proofing. After it drys I'll clean it up with a good sanding and then gelcoat the entire units. I'll also need to add some limber holes to allow water to transverse to the lowest point for the bilge pump to collect. Once they go in the boat then planks of the PVC boards will go in on top. Should come out looking mighty spiffy!
