Adjustable back stay
Gotro
Post by Gotro »
:macx: Replacing the back stay on my boat . Have decided to rig a 4 to 1 purchase with 1/4 in line at the single factory attachment point starboard for now and will post photos later.
Re: Adjustable back stay
Please do post your mod.
BTW...there are a few backstay mods in the mods section.
https://macgregorsailors.com/mods/index ... n=backstay
Gotro
Post by Gotro »
Here’s my finished and best effort for the backstay. Notice I tied off the working end to the mast support for safety.
Be Free
Post by Be Free »
Here's a 3-to-1 variation.
Bill
2001 26X Simple Interest
Honda BF40D
DaveC426913
Post by DaveC426913 »
As far as I was aware, the back stay on an X is virtually perfunctory. It comes into play under heavy winds, sure but overwise, shouldn't it effectively be slack?
My backstay is loose, and I believe I still have sufficient mast bend.
What do you know that I don't?
MacX 2000 Honda BF50A 'SeaSaw'
I would bridle into the center for a more positive pull on the mast
I done that mod yrs ago on :macm:
If u look closely u can see the end turning block on the traveler that its mounted to on my Radar Arch on the above pic
The pic below u can see the Traveler better
the reason it,s mounted on a traveler is as the mast rotates the backstay can b adjusted from port to starboard or reverse so as to always have a straight pull on the mast
Having an adjustable backstay improves ur upwind sailing & remember when easing the tension off that backstay do so very slowly
DaveC426913 wrote: Fri May 13, 2022 8:26 pm As far as I was aware, the back stay on an X is virtually perfunctory. It comes into play under heavy winds, sure but overwise, shouldn't it effectively be slack?
Well this for starters :) I would say :idea:
https://www.jollyparrot.co.uk/blog/when ... t-achieves
No pun intended
I hear u guys r having a heat wave in TO this wk-end enjoy
Be Free
Post by Be Free »
I know that I tighten my backstay when I'm running and loosen it when I'm not. I also know that it is much easier to attach the forestay when the backstay has been loosened. 8)
Bill
Honda BF40D
Ditto. Also a nice place to attach nautical banners. :)
Be Free wrote: Sat May 14, 2022 8:51 pm
DaveC426913
Be Free wrote: Sat May 14, 2022 8:51 pm I know that I tighten my backstay when I'm running and loosen it when I'm not.
Is this a performance boost thing, or just a safety thing? If the former, is there any evidence that it makes for a significant improvement?
Be Free wrote: Sat May 14, 2022 8:51 pm I also know that it is much easier to attach the forestay when the backstay has been loosened. 8)
Backstay is the last thing I attach. But I only raise the stick once a year. I guess if you raise and lower it regular-like, you are more likely to have the backstay attached when raising.
I have cried this far and wide, to anyone who will listen, and a few who won't, that attaching the forestay is far and away the most physically-taxing, blood-vessel-popping, frustrating task on my X. :x :x :x :x :x :x
I am determined this year to finally build a system that closes the gap between the stay and the foredeck chain plate long enough to stick that infernal pin in.
dlandersson wrote: Sun May 15, 2022 4:16 am Ditto. Also a nice place to attach nautical banners. :)
YES!
Ditto. The entire time we (at least one other person and I) are raising the mast and pinning the forestay, I keep reminding myself that the Macgregor ads talk about "raising the mast can be done by one person". :wink:
DaveC426913 wrote: Sun May 15, 2022 6:01 pm
Be Free
Post by Be Free »
dlandersson wrote: Mon May 16, 2022 3:05 am Ditto. The entire time we (at least one other person and I) are raising the mast and pinning the forestay, I keep reminding myself that the Macgregor ads talk about "raising the mast can be done by one person". :wink:
Using the mast raising system on the "X" and a loose backstay I've had no problem at all attaching the forestay. Crank down on the MRS just a little more than needed to get the masts vertical and the forestay pin slips right in. The only time I've struggled is when I've forgotten to loosen the adjustable backstay.
Bill
Honda BF40D
Be Free
Post by Be Free »
I'm not a racer. Been there. Done that. Burned the t-shirt.
That said, it is supposed to improve the sail shape so I do it when I remember. I'm more interested in having it tight when I'm running so I guess for me it's more of a safety thing.
Bill
Honda BF40D
Yes it can b very trying at times I use my old mainsheet vang to adjust my adjustable backstay so it,s an easy proposition but my 3 sets of shrouds r guitar string tight so I stll have to really crank down on my MRS so as to b able to pin my two hard furlers Jib furler on the bow & Genny furler 3ft out on the bowsprit "cutter rig" , so I,m now thinking "debating" whether to remove the Genny & hard furler & replace it with Code Zero soft furler & a 280sq ft light air Drifter which then can b installed & raised & lowered after the mast has been raised :)
