before:
after:
Process:
- power washed
- re-melded rough oxidized spots with heat gun (low heat, no gas in tanks)
- sanding where necessary
- plastic bonding spray paint
- a little reconditioning of black plastics and gaskets
I looked into new gaskets. Mine are a bit frayed at the edges but otherwise pliable where it matters to make a good seal.
You need to direct that to Piddle and Futz, I purchased the gaskets quite awhile ago. I do check them occasionally to see if they are still usable.
I was afraid of that. I hoped you had found a source that I'd overlooked. Fortunately gaskets are pretty easy to fabricate. The clouded and crazed fuel gauge not so easy.Piddle and Futz wrote: ↑Tue Dec 07, 2021 2:01 pm Well, I thought that I had found one here, but it turns out the web site is defunct.
http://www.valley-marine.com/gauge-with ... 30299.html
Spoke with the owner today and was told that the original tank is no longer EPA compliant and so parts are not made/sold for it anymore.
Could you just use a Dremel or something to remove the tabs?OverEasy wrote: ↑Mon Dec 13, 2021 10:48 pm The only thing that seems to make the newer Moeller Fuel Tanks “taller” is the currently EPA compliant fuel caps.
They have a protective set of ribs around the screw vent.
There are several ways to deal with it for a Mac26X are to :
>> trim off the tabs so the tank can slide in![]()
