(Oh, and for those of you that are anal enough to try and guess, that piston is from a Triumph 2000 saloon - similar motor to the GT6 and TR6.)
Sure there is. You have to spray the ignition wires with SuperCroil, which lubes the path of the electrons, reducing resistance, and giving better mileageThere is no possible way you're getting a 10% mileage improvement from changing spark plugs.
These were great - thanks Chip, I had forgotten about the water injection - that was a classic...Don't forget the fuel supercharger (an unpowered propeller inserted between the carburetor and intake manifold); "water injection" consisting of an vacuum line bubbling through a container of water. Not to be confused with real water injection which actually worked in some applications.
Also, the 100mpg carburetor, proven, patented but not available to the public because it was purchased so it could be supressed by (take your pick) the evil U.S. Government, the oil companies and/or all of the big three auto companies.
Not a mileage gizmo but my favorite was the toilet paper oil filter.
Indeed! Most of them were total rubbish. I love those turbo-blades you stick into the intake... and anybody here remember the "Fish Carburetor" company? Ahh.. sweet memories... grab an old J.C. Whitney catalog from the 1960's and you'll get a real laugh, for sure.Chip Hindes wrote:Don't forget... "water injection" consisting of an vacuum line bubbling through a container of water. Not to be confused with real water injection which actually worked in some applications.
That was the base engine for the Tempest starting, IIRC, in 1966. We had one. The optional motor was a 326 or 389 in the GTO.Chip Hindes wrote:Are you sure that Tempest had a V8? I seem to remember the "big" motor for that car was an OHC straight six with a fiberglass drive belt, which I believe were both industy firsts in the U.S. Or was that just another option?
Yes, but by then I'm 99% sure they had gone back to the conventional tranny behind the engine. It was the early sixties version that had the rear mounted transaxle.Moe wrote:That was the base engine for the Tempest starting, IIRC, in 1966. We had one. The optional motor was a 326 or 389 in the GTO.
Yes, actually the same engine for Buick, Pontiac, Rover & the Triumph TR-8. I have a 1970 TR-6 too, but the TR-8, when running, was a vastly more modern, comfortable and fast ride than the TR-6. Besides, it also has that unmistakable V-8 rumble (instead of the 6's brrrrrp)! I recall that GM bought the aluminum V-8's tooling back in years since 1980s, but cannot recall to what purpose .... anyone?Chip Hindes wrote: ... I had no idea the TR was a Pontiac V8; always assumed it was a Rover; or was the Rover actually a Pontiac as well?
Here's another question. Does anyone know if that Pontiac is actually the 60 degree aluminum V8 which originated at Buick?
