Rebedding Deck Hardware
Be Free
Re: Rebedding Deck Hardware
Post by Be Free »
On my Honda the remote control was mounted rotated 90 degrees to the stern with the shift handle pointing straight back. I believe this was the standard procedure for our boats. There are mods to rotate it back to the horizontal position. I tried them but I found that the cable was either in the way or had a too small radius which increased friction. I ended up putting it back.
There is a large loop in the aft berth to allow for the multiple turns required. There is an s-curve from the remote to the down tube, a 90 degree change where it comes through the tube in the pedestal, then a 90 degree turn to starboard to get to the tube that goes into the engine well, and finally another 90 degree turn to connect to the engine. There might even be be a couple more :?
You can use adhesive zip tie anchors and zip ties to keep all of the wiring coming out of the pedestal close to the ceiling of the aft berth. Attach the steering and shift cables first and then use them as an attachment point to run any electric. You will need a fairly large loop at the engine to allow for steering and tilting otherwise you will kink the cable right where it goes into the engine.
The cleanest and shortest run would be from a horizontal remote straight back to the engine but I could not get that to work without the cable being in the way when walking around the pedestal.
Get the best cable you can. You will be glad you did.
Bill
2001 26X Simple Interest
Honda BF40D
Be Free
Post by Be Free »
pitchpolehobie wrote: Tue May 18, 2021 1:43 pm That looks more like a power cable to me than the steering cable...
The two cables that are molded together are the positive and negative power cables. They will run back to the battery (there may be switch(es) but electrically they are connected to the battery). The small black cable going down contains all of the wires that run back to the remote control. The grey and red are the throttle and shifter cables. The steering cable is not in the picture. It runs almost about foot forward of that area.
Bill
Honda BF40D
