Testing the electrical, there was no power to the fuse / switch panel. Clipping a battery charger on the bus behind the panel, I was able to test things out (lights, stereo...etc).
We have 2 batteries with the typical 1, 2, both, off switch but no connection to the fuse panel. I understand there should be a fuse between battery and the panel, but haven't found it yet, and unsure where the power cable runs. I was able to feel 4 or 5 cables running down the port side behind the panels, but tracing the main is hard since everything behind the panel is very tight.
So my first question: Does anyone have an idea where the main power connects? It goes to the back of the boat somewhere, but seems it's under the ceiling panel/cockpit floor. I'm temped to just connect directly to the battery, but if it's just a simple fuse or connection that would be best. I just can't seem to find it.
Also, I blew 2 fuses - a 6A to lights (polarized backward for LED swap) and a 5 amp to Instruments. I'd guess instruments would be better with a higher rating and their own inline fused wire. Lights maybe a 20 amp since it seems our stereo (which has a 15 amp fuse already in it). Did these boats originally have low amp fuses or could this be a previous owner fix?
Tom
I did see this diagram, thanks to whoever posted it, this is how mine is pretty much hooked up from what I can see.
