Here's how we mocked the steering up yesterday. That is not the rod we plan to use. We mocked it up with a piece of galvanized rod, a coupling nut, and our original steering rod. We're just trying to get the geometry right before we build the final assembly.
Because the engine is set back 5.5 inches, we moved the clamp with the ball out to the end so that it's as far to the stern as possible. This moved that connection point back about 3.5 inches from the original position.
We also have the connection on the engine as far back as possible. This seems to give the engine the best swing and it closely matches the rudder swing. Mounting the ball & socket on the bottom of the outboard arm is preferable because it gets things as low as possible (less tripping hazard). Also, there isn't room between the cowling and the arm for the ball & socket on the top in that hole.
The problem we are having is when the engine is tilted, there is interference between the ball & socket and the engine. Although we plan to disconnect the motor when sailing, we want the ability to leave it connected and still steer. I've ordered one of these rod ends https://www.amazon.com/gp/product/B071D ... UTF8&psc=1 to replace the ball & socket. I'm hoping that we have the same range of motion in a smaller package. We won't have the quick disconnect, but it's not really needed on the motor end of the connection rod.
This is a work in progress and I'll update everyone on how this turns out. Also, please provide any suggestions you might have.
Jeff
