For my main Anchor and selected a Galvanized 13lb Mantus M1 - https://www.mantusmarine.com/
They had a sale recently and it seems to be a good all-around Anchor. I thought about a 17lb, but that just seemed overkill and I can always use my secondary Danforth's if things get really rough.
For a bow roller, I've look at many options (and even acquired a few), but I've finally settled on a SeaDog Medium Anchor Bow Roller
https://sea-dog.com/groups/3015-medium- ... bow-roller
Its right at the size limit to fit on the boat (Length to Anchor locker, Width, etc) and provides flexibility. I am going to upgrade my forestay and install CS Johnson Quick Release forestay levels to raise the height of the jib (I have a CDI Roller Furler), which also helps to provide more room for the Anchor roller. I've seen multiple posts on forestay mod, so I'm sure you can search/find that on the site. If I do end up needing to replacing my forestay due to wear, I'll upgrade to a larger wire just for extra security. I'm also going to need to move the bow cleat on that side as well, but that's not a major issue.
I also picked up a Mantus Anchor Guard (on sale) and will see how that works out. Again, it could be overkill, but looking to make it as secure as possible. https://www.mantusmarine.com/mantus-anchor-guard/ More on that later once I get it installed.
My current dilemma is if/how to reinforce the bow to support the anchor and bow roller. The Anchor Roller only partially sits on the pulpit and it's going to hang over the front (this is normal), but I'm still a little concerned about how much it's going to stress the bow area to have a 13lb anchor on the nose bouncing around in the waves (I'll remove it when trailering). I'm going to put in a large backing plate under the deck (likely using 1/2" UHMW) as it is strong, no issues with corrosion (galvanic or otherwise), and easier to work with. I'm still debating having a stainless plate made for the bow to set on top that provides more surface area and stick out under the bow roller part of the way (3-4") to provide additional support. Again, this could all be overkill and I have a habit of over-engineering everything, so looking for some feedback.
I attached some pictures where I just have the bow roller sitting on the bow for sizing, etc. Nothing mounted yet.
Feedback ?
-Dennis
P.S. I have a like-new BW Yacht bow roller if anyone is interested as well as 13lb bruce anchor & unused bow roller. Installed the BW Yacht bow roller for a few months last year before I decided to switch to something that could store the anchor. I'll post it in the classifieds.
