Inquisitor wrote: ↑Tue Jan 12, 2021 9:25 am
kmclemore wrote: ↑Tue Jan 12, 2021 8:53 am
Well, I’m certainly flattered but I’m not sure what sort of advice you’re looking for. Is it about the spraying process or the materials (urethanes, thinners, etc.) or ??
Thank you Kevin.
Having never sprayed polyurethane,
- Is it safe? - I've read paint like aircraft Imron will flat kill you without the right air gear.
- I'm not looking for selling quality furniture grade results... just better than what I see with brushing.
- The can recommended and I used 4 coats on this project, but the more it built-up the more wavy and brush strokes are visible.
- Like I mentioned above, I prefer the non-yellowing of this specific product. All others I've tried - polys, lacquers, spar, varnish... etc seem to yellow and seriously change over time. This one on oak flooring never yellowed. I could put a piece of the raw wood next to it and can't tell a color difference.
- Does spraying take a long learning curve before a Noob can get better than brushing results?
- Since its a water based Poly, I'm assuming I just thin it with water??? How do I tell how much? - Trial and Error?
- I got this on sale... well... because it was on-sale $9.95 and some day, I might use it.
I wouldn't use it on my own car, but for a wood project, I'm game.
Wow... that's a PILE of questions.
Is it safe? Well, no, not without protective equipment, but yes, it can be with the right stuff. In general, most 1-part poly can be sprayed while wearing an OSHA respirator (note I did NOT say 'mask'). 2-part poly is much more hazardous and requires an air supply and significant breathing apparatus. Water-based acrylics don't create a real hazard at all, so a light duty respirator would be plenty.
Coats of poly (urethane or acrylic) can definitely be applied using spray, which would eliminate the brush strokes. However, to avoid clouding of the finish, always use gloss for your undercoats and your last coat can be whatever you like (gloss, semi-gloss, satin, flat, etc.). Gloss has no flattening additives and won't cloud, but non-gloss finishes have an additive to flatten the finish and when you use multiple coats it ends up being really foggy and sometimes even a bit white-ish when you're done. With oil-based polyurethanes you can apply as many coats as you like (although I'd stop at 4) but with water-based acrylic paint, I'd avoid more than two coats on darker woods since it can get a little cloudy with successive coats no matter what gloss level you use.
As to yellowing, yes, polycrylic is the way to go - I don't know of any polyurethane that will not impart some level of yellowing. That being said, that little bit of yellowing to me is quite pretty, but more importantly the urethanes are going to be MUCH better for a marine environment since acrylics aren't particularly durable in damp, hot conditions. Urethanes are available in both water-based and oil-based, but I prefer the latter - again, because of durability.
Thinning of water-based paints should be done with great care and in considerable moderation. They really don't need much thinning - they're already pretty thin - and if you add too much water the properties of the coating can be altered, causing the finish to not be what you expected. Frankly, I'd avoid thinning water-based coatings if you can.
