I'm kinda reading it like there's too much (and some incomplete) data here ... so maybe it's best to go back to basics.Inquisitor wrote: ↑Fri Dec 18, 2020 6:01 am.....Doesn't this data permit some battery health evaluation... ??
When it works well your battery will make a good cranking battery .... Except it is not a sealed Lead-Acid, which means it could exhale hydrogen (and other toxic gasses) while it's charging .... I'm sure you understand the "Big Bang Theory" of hydrogen applies in your Mac too
But putting that to one side for the moment, the first thing to consider is battery capacity retention over time. A good unused battery will still put out well over 12volts days and weeks after it's been charged.
The next thing to consider is it ability to handle a high current (heavy) load. But the load needs to be constant to get enough time to measure it effects on your battery properly. That's why I've said previously "It's worth investing in a cheap $25 battery load tester to see what happening with your battery". ....https://tinyurl.com/yyepz7k3
With your unsealed battery I'm sure you know that all cells need to be covered/topped up with distilled water (or battery water) but it's also good to check the "Specific Gravity" of the fluid to highlight a dud cell. https://tinyurl.com/y8tbqkm4
My guess is your battery has Sulfation in one or more cells. So if I owned your battery, after top-up and charging I would....
1. Wait 3 days and check the voltage and off and on a load .... and if that's not Ok I would...
2. Assume it has Sulfation and put it on am Intelligent High Voltage Pulse Charger (HVPC) ... I have one similar to this https://tinyurl.com/yaaenezv
3. Measure the Specific Gravity in each cell.
Please note a HVPC can break a battery (and any device connected to the battery at the time) ... but there's nothing to lose if the battery is not working properly anyway.
Hope all my rambling helps
