The 'bunchy' cords have not rusted and I will run out there today after lunch to get a picture.kurz wrote: ↑Wed May 06, 2020 8:54 am well, the just cheapest ok-instal was to use heat shrink tubing with glue and it would have last a long time. And hang at least the connection high so it gets not in touch with (salt-)water ever...
I like your bunchy-cord solution. What I normally not use is non-ss-metal in the boat. Having rust can really make your boat dirty. But maybe the cheapest was to use plastic hooks.
But to be honest I don't really think that water can penetrate the isolation of a cable? Or can it?
And yes - PLEASE - send photo from your Install Boat![]()
By the way, how dit your local store installe the motor wires in the? New cables in only 1 piece or did they connect the wires (in a better way...)?
The dealer on 'boat' was Captain Mike Inmon. His people do an 'okay' job on the motor install. They do get all the cables laid in one piece, no splices, with good crimp fittings on the perko but they do indeed lay the wires in the bilge
I have also be really lucky that I have not really had any salt water come in at all ever because I have boots (of my own design) on the motor linkage.
Most of the water I have heard about in M boats is rain water or hose water. I suppose if your aft is really heavy you could get salt water into the boat from the rudders.
