I don't know which model best suits my needs, or could be made to best suit my needs. I recently went to see my first X in the flesh and I was underwhelmed by the size of the head, which I'd read was a big selling point on going for the X over the M. So, now I'm looking at the M and thinking about mods. I don't like the thought of debris falling into the aft birth because of the open ladder design and I wondered if a bulkhead with an L-shaped galley was do-able. I've only seen two bulkhead mods on the Mac, but I've seen quite a few sailboats with the setup I'm referring to. Here is a 1980s Wellcraft Starwind 27, for reference:
I believe something similar could be done with a Mac 26M, with a bulkhead setup similar to what Currie did, though the starboard side would be open as it is on the Starwind.
Having the first step be a little high, but being a fairly deep work surface would give an additional seat for someone to trim sails while in the cabin. Integrate steps into a cabinet like the Starwind, and you have a fairly easy entry into the cabin, though you give up a little of your sole. The galley would likely need to be made stationary, though the slide feature could be kept, if desired, with a change of the countertop and use of a fold flat sink like a deep Dometic fold-flat sink.
Thoughts? Am I overthinking this? Is debris not really an issue? Would rear birth access over the starboard seat be too inconvenient or difficult? What the heck is under that hump at the bottom of the stairs and would it be too inaccessible with this setup?
