Mine was retrofitted with a second axle, after moving the original forward. But I have a lot more clearance between the axle and the frame. Possibly due to changes in the shackle arrangement, since it's an equalized leaf system.
But the OEM springs are
very stiff. They have much thicker leaves than aftermarket springs, and a much higher calculated stiffness than what you get with typical 4-leaf 1750 lb spring packs.
But having said that, it sounds like your axle is too close to the frame. And what is that between the axle and the spring? It looks like a spacer, which will put the axle close to the frame while lowering the trailer. Maybe someone added that, 'cause it doesn't look original.
Here's a pic of an OEM 26X trailer I found somewhere and saved.
Someone else's trailer, but I think it's for a 26S or D. Notice the axle under the spring instead of over it.
Mine, showing the OEM axle. Lotta room in there. You can also see that I removed a couple of leaves from the spring pack to soften it up, as they were the originals, and intended to take the entire load on a single axle.
That floor jack is helping me get the CB back into position after it fell due to an overzealous Mac Bump® allowed the boat to move too far forward without the CB being properly supported by the line. Has nothing to do with this spring thing.
