windypatrick wrote: ↑Thu Jun 04, 2020 1:51 pm
FWIW, I've enclosed a rough schemetic for Dragonfly, The Blues Sea downloadable installation information includes a chart to help you select fuse size. They will be large.
Ok, THREE batteries. That complicates things.
I don't pretend to understand your schematic, although I gave it a shot. My first comment is that it looks like a lot of on/off switches. Would some of those be better served with selector switches that could be left in "combined" mode?
https://www.ecosia.org/images?q=blue+se ... 5E76C87DFA (like S4 and S5 for a specific example, couldn't those be a single combiner?)
You have a dual-bank battery charger, but it looks like you have to play with S-4 and S-5 to make sure it gets both house batteries? (Maybe you need a second ACR between these two batteries?) I only have two batteries, which simplifies things for me. I used to have a dual-bank battery charger but when I added the ACR I took the opportunity to downsize it to a single-bank charger that does both batteries through the ACR. Saved a bit of weight, space, some complexity, and a bit of wiring.
The ACR is there to allow BOTH the solar panels AND the engine alternator to charge both banks of batteries simultaneously. I can sort-of see how that might happen in your schematic, but it's not obvious to me.
Boat: you likely don't have an ACR: it's not a factory thing. The ACR has two positive lugs, each one connects to a positive terminals of one of the two batteries. The ACR has one negative lug that connects to one battery (but the negative terminals of the two batteries are connected together anyway, so the ACR is connected to both battery negatives). When the ACR senses a charging voltage on ONE of the battery terminals it allows the charging voltage to be delivered to BOTH batteries. That way you can charge BOTH batteries automatically by just running your engine or solar, instead of having to use the selector switch to determine which battery gets charged. When the ACR senses that one of the batteries is being discharged, it separates the two batteries automatically so that the selector switch governs which battery gets used.
WindyPatrick: I guess my question on your wiring diagram is: like I said to Boat above, the ACR is there so that you don't have to fiddle with switches to automatically charge both batteries from either your alternator, solar, or single-bank charger. Somehow your diagram makes me feel like you are still going to have to play with switches? But maybe that's just me not understanding. Actually, most likely that's me just not understanding. But isn't the point of the ACR to do things automatically?
