adudinsk wrote: ↑Mon Jun 15, 2020 6:27 amAlso.. the main sail has a Shackel at the Tack , should I use that, or just attach the tack grommet directly to the mast?
Run the sail up the mast without securing the tack. Then see where the tack wants to be for a smooth leading edge. That's the space that needs to be taken with hardware, of whatever sort works best.
My main sail had slides added to the original bolt rope. The whole tack area looks strange, until I figured out that I needed to change where the tack secured to the boom. It was pulled way too far forward, leaving wrinkles and bags in the bottom of the sail.
I drilled a new hole in the boom, added a thin pin and twisted shackle, and not it sits nice and flat. For a worn out old sail, that is. But no more wrinkles and bags at least. The tack termination ended up moving back by about the same amount that the sail slides spaced the sail back from the boom.
Big surprise, that.
