Check your outboard internal anodes
Re: Check your outboard internal anodes
the dude wrote: Mon Jan 20, 2020 7:22 pm the big question that comes to my mind is "how many hours are on that engine
You could plug something like this in to get diags
http://www.brpdiagnostics.com/honda-dr- ... iagnostic/
the OEM anode is aluminum alloy, not zinc
What I've learned is that zinc is used for saltwater and aluminum for brackish water.
So OEM might be targeting the middle of users. Aluminum in saltwater would deteriorate faster than zinc so you are doing pretty good for 19 years.
More here:
https://www.westmarine.com/WestAdvisor/ ... -Corrosion
BTW, if you don't have one, you can D/L Honda manuals here
https://m.marine.honda.com/owners/manuals
adudinsk
Post by adudinsk »
Yes. Agreed
I went to my local Merc. dealer, and he had NO IDEA what I was talking about
I gave him part numbers, said he never sold/saw these internal anodes
Called the supplier for the region, HE SAID he never saw/ sold them
Ordering online...
Will be the first thing I replace.
(hope they are not rotted in)
AD
adudinsk wrote: Tue Jan 21, 2020 8:17 am Yes. Agreed
Makes you think that they are a lifetime part.
I'm no outboard expert, but again, I've never heard of these internal anodes, EVER. Yet they seem to be made to be easily replaced.
This guy replaces them EVERY YEAR. Strange that your dealer has never sold one. Again, it reinforces the idea that they are a lifetime part.
I would think that gunk and bio stuff buildup would hinder their effectiveness. Like insulating them from currents.
At the very least, cleaning them seems to be in order. I wonder if there is a way to clean the bio-junk from the inside of an engine's manifold without taking it all apart? Flushing with fresh water doesn't seem to be enough. Yet I don't want to damage parts with acids and corrosive liquids.
adudinsk
Post by adudinsk »
Yes, they are supposed to be replace every few years in fresh water, and sooner in salt.
The Merc. ones you MUST replace the entire cap/rubber seal/anode as they do not sell it any other way.
Other brands you can (as the video shows) only replace the actual anode.
My 75HP merc has 3 of the 2 on the block one up by the head. all are the same and attach with 2 bolts. (do not over tighten)
they are about $30us (+/-) each.. plus shipping.. handling.. duty..blah..blah..
Interesting enough the SAME anodes are listed for some Yamaha outboards.. although I am not inclined to believe it...
https://www.boats.net/product/mercury/804085A01
Unless the bolts are rotted in.. should be a trivial task. Much easier than an impeller for the water pump. (although that easy.. just a pain to do)
AD
adudinsk wrote: Wed Jan 22, 2020 10:38 am https://www.boats.net/product/mercury/804085A01
The link says "COVER/ANODE KIT". I wonder if that's a kit for ALL the anodes? At $30 a pop, that seems pricey.
I just ordered an anode kit for my Suzuki and it included a bunch of anodes including the bottom plate under the motor mount that touches the water, for $27. And, it's magnesium which is preferred for fresh water.
https://www.defender.com/product.jsp?id=3945220
Link? Part numbers? :cry:
Ordering online...
AD
dlandersson wrote: Thu Jan 23, 2020 2:57 am Link? Part numbers? :cry:
Mercury
I order my Suzuki parts from
This company seems to know the most about anodes and what type to use in your boating waters.
http://martyranodes.com/sites/default/f ... AT19_0.pdf
DaveC426913
Post by DaveC426913 »
Russ wrote: Mon Jan 20, 2020 6:25 pm One question still exists; does leaving the motor foot in the water increase anode deterioration? Would tilting it up be advisable?
I think it's a function of the motor running, but I don't know.
Regardless, it should not factor in to your decision of how to tilt the motor. There's a lot bigger factors going into motor stowage than the paltry cost of replacing what is - by design - a sacrificial part.
Bobsquatch
Post by Bobsquatch »
[/quote]
As far as leaving it in the water, that depends on if there is any stray current in your boat. In my old cabin cruiser the electrical system was a mess. Many previous owners. I had twin engines so twice the annodes and exposure. I was never able to clear the water (per design) with my stern drives. My anodes could barely keep up when plugged into shore power. The issue is potentially damaging to the parent metal if the annode is insufficient. Given the option, I would never leave it in the water to complete any potential circuit. Our boats' electrical system has always been suspect and none of our boats are getting any newer. Given the choice, never leave the engine in the water. Particularly if you are connected to shore power. If you have a compelling reason to, keep a good watch for annode deterioration and foot damage. Annodes get real cheap if you end up replacing the lower leg.
adudinsk
Post by adudinsk »
My outboard is a 2005 Merc 75HP
Its model 1F75412D3
The "KIT" is called in the Merc parts manual as a "COVER" which is the entire unit
Part 804085
The motor (mine) has 3 of them, use EzPartsWeb to locate where they go.. or poke around the outboard once you find one.
Full part number is 97-804085A01
Andrew
adudinsk
Post by adudinsk »
Also in regard to the stray electrical current..
Yes.. that can destroy anodes QUICK if your plugged into shore power, and have anything AC connected to your DC system..
ie Charger, etc..
that could cause a problem.
A Galvanic Isolate will fix this, (make your own.. a heat sink.. 2x 50Amp bridge rectifiers.. 2 led's for indicators to be legal.. total cost under $20,,... plus a case/box/etc as fancy or simple as you want)
adudinsk wrote: Tue Jan 28, 2020 5:51 am Also in regard to the stray electrical current..
ie Charger, etc..
I don't have shore power, but this is fascinating stuff. I would so much build one myself rather than pay what commercial ones cost.
Would be cool to see a mod like this for $20.
I found more here https://www.boatus.com/expert-advice/ex ... -explained
adudinsk
Post by adudinsk »
Yes.. good post.
The galvanic isolators are STUPID expensive.
All they are is a heat sink, 2 50A (etc) bridge rectifiers, a case, wire, and if you want to be "legal" you have 2 LEDs (I would use a 1K ohm current limiting resitor in series with each) for indicators.
Took an old heatsink off a video card, had boxes of Bridge Rec's from my pinball machines, 10 min job.. hardest thing was mounting neat to the heat sink.
An old article
to add LED MONITORING...
use 2 posing LEDs with a current limiting resistor..220 Ohm/330 Ohm/1K Ohm etc.. connect each to in and out of DIY isolator.
AD
Got my "anode kit" Freshwater Magnesium version.
It's for Suzi 90+ but I think it will have what I need for my DF70.
I may have some extra parts, but I'm going to install what I can.
adudinsk
Post by adudinsk »
Lucky, your kit has JUST the anode for the engine block.. so you just replace the anode.. not the whole "cover"
Merc... no can do.. they ONLY sell the entire unit with anode.. I wish I could get just the anode.!
AD
