I couldn't find the model you mentioned, but the N1090 only draws about 1/10th the power. 4.5A at 12VDC (56W at 12.5V) and 2.4A (30W) in night mode. And I can't hear mine run at night, either - I can hear the relay opening and closing, but not the compressor. And it, too, gets very cold, very fast. And I'm very happy with it.BOAT wrote: ↑Fri Jan 10, 2020 9:12 amWhen it DOES cycle (which is hardly ever if you installed it right) it does draw 5 amps so that's 600 watts and that is why they have that ridiculous spec on some of the smaller units. The T1090 is the only one specially designed to fit up against the roof of the Sprinter - that saves a TON of space in the van.
https://norcold.com/product/norcold-de- ... rigerator/
Click "Technical Details" for the power specs.
