Pop top gas spring mounting
- Seadoc
- Sailboat: MacGregor 25
I'm adding gas springs to my 85 Mac 25. Can the mounting plates be fixed with screws or are similarly sized bolts better? The holes will fit #10 or M5 screws.
Tedd
Re: Pop top gas spring mounting
I'm not familiar with the structure of the 25 but I assume it's similar to my 26S. I'd be inclined to through bolt if you can, using washers with larger than standard OD. It's generally a good idea to spread out the load on fiberglass, where feasible.
