Could use some advise
Just noticed this. Does it look normal? Is it something to get done quickly? The pin is not loose, and not about to come out.
Nauti Nell
Re: Could use some advise
Post by Nauti Nell »
Isn't there a ring on the other side that keeps the pin in the hole. Or are you asking about the crazing in the gel-coat?
I find it interesting that the cap plate is welded to the chainplate. On the :macx: , the cap plate just slips over it and is sealed with caulk or tape, but it carries no load. Those small screws look like they're carrying at least a little load for that crazed gel coat. Or maybe it's doing what gel coat does - crazes with age and very slight movement. But either way, mine have no crazing around the chainplates.
Sumner
Post by Sumner »
If the pin keeps walking out in that direction and results in forces on the ring then I would turn the pin around so that the forces are on the head,
Sumner
The MacGregor 26-S
The Endeavour 37
Mac-Venture Links
Nauti Nell wrote:Isn't there a ring on the other side that keeps the pin in the hole. Or are you asking about the crazing in the gel-coat?
Cracks in the gel coat. There is a ring-dingy, that is why I said the pin is not coming out.
Sumner wrote:If the pin keeps walking out in that direction and results in forces on the ring then I would turn the pin around so that the forces are on the head,
Sumner
The MacGregor 26-S
The Endeavour 37
Mac-Venture Links
I don’t believe there is a problem with either the ring or the pin.
It was the cracks in the gel coat that caught my attention.
Is this a problem, normal?
Post by Jimmyt »
There is, apparently, a backing plate that is bolted through the hull just below the rub rail. It appears that the two small bolts hold the rig and are supported by the backing plate. Although I haven't seen it, I can't envision a backer with that bolt pattern that wouldn't flex a bit - probably more than the gel coat.
Ray - did you check to see if the fasteners are tight? If they are, I'd probably fix the spider cracks and seal around the plate and go sailing. If that deck was the only thing holding the rig up, then I would be concerned. I haven't seen the backing plate, but that has to be what those three fasteners are below the rail.
Jimmyt wrote:There is, apparently, a backing plate that is bolted through the hull just below the rub rail. It appears that the two small bolts hold the rig and are supported by the backing plate. Although I haven't seen it, I can't envision a backer with that bolt pattern that wouldn't flex a bit - probably more than the gel coat.
Sounds like a plan.
I just checked the screws for tightness; they were not budging.
The boat is thirteen years old, and I never noticed the crazing before. The crazing may have been there for twelve years. I just noticed, and wanted to check on this board in case there was something I should imminently be concerned about.
Post by Jimmyt »
Excellent! Otherwise, you would have to have long arms to hold the screwdriver and turn the wrench at the same time...
Or have the the very accommodating wife hold tightly. Son’s are too far away.
Post by Jimmyt »
sailboatmike
Post by sailboatmike »
Nothing to worry about, its just because the shrouds pull at a angle to the chainplate that causes the cap to move a little every time you tack and the weight and force is taken by shroud.
Gelcoat is very brittle so cracks pretty easy with any sort of movement
Post by BOAT »
I just got back yesterday from three days on the ocean - have not even washed the boat yet. I used the microscope setting on the camera.
So, what am I supposed to be looking at here? I'm looking for barnacles? what?
Boat,
I’m going to guess that 13 years of stress crazed the gel coat. As I said, I just noticed it. Who knows, there may be a difference between a 2013 & a 2005 :macm: More than just eight years. :|
