Calling for your help and advice. Prior to begin any work on the boat I want to identify all the bolts involved in the swing keel system.... I want to remove the keel to check all the parts, change the cable, put back a manual winch (with a clutch) sandblast the keel and change all bolts that need to be.
So if you could go trough the few attached picture and comment ... thanks
Hope you will be able to open the links, didn't find out how to put the images
https://scontent.fyhu1-1.fna.fbcdn.net/ ... e=5B5C245A
https://scontent.fyhu1-1.fna.fbcdn.net/ ... e=5B66ABFA
If you could add picture of your own venture to be able to compare... thank you very much
Venture 21 pivot Bolt
Re: Venture 21 pivot Bolt
Looks to me like someone did a shoddy repair at some point. I dont know what purpose a piece of wire would serve glued into that mass.
