OK guys--Just returned from the BWY Rendezvous at Port Orchard Marina and am ready to put the hull color debate to bed. Blue and white are both slower than Black.
Todd and Cheryl McChesney, the owners of Blue Water Yachts, unveiled their new customized 26M at the rendezvous which they described as a concept boat. The boat or a similar one is not for sale, but she has lots of interesting new things that Todd is trying out which may find their way into the retail world in the future.
The boat is a
Black
hulled M with a "Pirates of the Carribean" theme named Perla Noir (Black Pearl). By reducing thickness of hatch covers (with same molds), using composite rigging, leaving off the head door, going with the Tohatsu 70 instead of the Suzuki (saves 45 lbs.), Todd was able to take about 450 lbs out of the top of the boat. He then cast a lead "torpedo" which is attached to a stock, but strengthened, centerboard which adds 450 lbs to the keel. A new 6:1 lift mechanism just aft of the mast allows the board to be raised and lowered. With the new keel the boat is sailed in normal winds with the water ballast drained. This means the boat is net 1100 lbs lighter than any other M when sailing. For really nasty conditions the water ballast can be added for extra safety.
The boat has a new adjustable bowsprit which runs through a new "banjo fitting" which has the new assymetrical spinnaker attached. The aft end of the bowsprit is attached to a traveller just aft of the anchor locker which allows the bowsprit to pivot.
A new set of carbon sails was fitted for up wind work. (drool)
Lines led aft also control the amount of rotation in the mast rather than letting it hinge free.
Composite shrouds, stays, and new running backstays which run to the Genoa track are also fitted.
On top of all this Todd finished the boat with three applications of 3M polish and 4 coats of wax. The whole boat looked like a black and white mirror.
Here are some pics of the boat:
Carbon jib
Bowsprit Traveller
6:1 C/B Retract Mechanism
Tohatsu 70
Perla Noir
Proud Papa (Todd)
New Sail Prices
Black Hull
Composite Rigging
Composite Backstay
Spinnaker Flying
For you guys that like to discuss X vs M sailing speed, the results in the "Not Quite a Race" were First: X, Second: M, Third: X. Incidentally the first place X was piloted by Frank Mighetto or maybe it was wife, Lisa while Frank took a nap.
