The rudder stock on the J21 is stainless steel. They need to be able to take a hit from a whale.
The keel is solid steel - Hugo Boss J21 broke rudder in vendeeglobe but not the keel - the keel hit the object first and the keel held firm but it broke the metal rudder at the cassette shaft. Alex saw the rudder dragging behind the boat at 22 knots and the hydro-generator got busted off too - (no electric power generation for the batteries).
He had to fix both on the fly.
Steel rudders are the best - but no good for the MAC because the transom mount is not strong enough to support the steel rudder on impact - the transom bolts will break out the transom before the steel rudder would break - so a super strong rudder is not a good idea unless the transom has steel plates in it also.
Actualy - steel plates in the transom to mount stronger rudder brackets for steel rudders is not such a bad idea for the MAC but the real issue here is speed - the MAC will never see the kinds of speeds that break off steel rudders so it's kinda usless - I must admit that I do worry that hitting a whale at 7 knots might pull the rudder bracket bolts right out of the transom and make a hole in the boat.
Man, just saying that is sort of scary.
