So, the mast on my
I have read the threads and wish I could find an old Hobie 18 Mast and perhaps an old boat actually to install rotating mast hardware? I want all the sail I can get so will not go below 28 feet on the mast and would be willing to go up to 31 (if the weight was correct).
I'm also of the idea that the single spreader system is not enough. I've seen too much flex in this mast for my comfort.
So, here 's what I want/need/dream about.
1. A Hobie 18 mast (probably easiest / cheapest)
2. Fix my mast (I've read the threads about cut it / make plug or sleeve system / 2 piece) This is an option I guess.
3. Carbon (did Mike ever make Carbon masts?)
4. Install an
The problem with 1, 3, and 4 is needing the material in SE USA (Gulf Shores to be exact).
If I see Travis coming down the water way again, or Chinook makes another loop... Piracy may be involved.
Does anyone have one they want to sell? Anyone recommend an option?
I would be willing to get nuts and do the carbon / synthetic rigging thing maybe too. Although most standard carbon masts out there at this height are too heavy I think to gain advantages?
Thanks team. Help!
And oh... where is Peaches at lately?
Ed.
