Hi. Lovely day yesterday for the first main raising, gusting to 5 knots, dead flat offshore SW. Baby asleep below, admiral also taking 5. So I connect the boom, using the halyard as a topping lift (ill install a topping lift after I get a MRS to lift and drop solo) . I can see the gooseneck is raised about a foot. The original bolt rope feed widening is blow the gooseneck. The main sheet just kisses the front of the Bimini when centred - made to measure. I lay out the main on the deck and low and behold, it has had slugs fixed and is a free footed sail. Cool that's one thing I thought I'd do but don't need to, now I'll get lazy jacks, run the halyard back to the cockpit and bobs your uncle I'm solohanding while the admiral parents.
Time to raise the main and Instead I'm scratching my head, look again, scratch again, put away main. so can anyone see a solution
M26 mods-05
M26 mods-02
M26 mods-03
A plate has been screwed over the track widening. (With steel self tappers rusted in, that'll be fun removing) Does this mean I have to drop the mast and feed the sail in from above and raise the mast with the sail on/
Or am I meant to unscrew the plate to raise / drp the main?
Seems like a design to keep the main living on the boom, but there's no lazy jacks anywhere that I can see..... not for soloing obviously
