I suspect it is a 1996, however when I google them, I can't find much info, and the only 3 cylinders I can find are 60hp. The 50's seem to be 2 cylinder mostly.
Anyway , so step 1 : what is this?
I did look for the model number plate, and can't find anything, I think it was supposed to be on the left side on the tilt mechanism, but I can't see anything there.
Step 2 .. it is really hard to get this thing started, usually like 15 mins+ of cracking on and off. I noticed that it can kick over if I spin the red valve on the right side, .. but then it will die after a little bit. I think this closes the fuel off, I think this is the fuel pump. I also manually pull the throttle open to try to give it the gas it needs, as it needs extra for the first mins or so once it catches. The key has a "push in" mode that I think is supposed to do a shop, but I am not sure if it works.
The annoying part is that it just sits thee going puffed puffed puffed.. for a long time. Once started, if I try it off it usually starts right back up .. but if I wait 3 hours, it is like starting all over again.
I have no idea what condition anything in this engine is at .. I expect other then new spark plugs I put in last year, everything is old. I assume the water pump, fuel pump starter ect are all original.
thoughts?
Would video help?
