Installing Stern Rail Seats for 26M
jbm8785
Sailboat: MacGregor 26D
Post by jbm8785 »
Anyone done an installation of stern rail seats on their 26M?
Got plans from BWY when we purchased the seats, but very difficult to read.
Looking for any and all ideas, tips, etc.
Many, many thanks!!!!!!!
kadet
Re: Installing Stern Rail Seats for 26M
Post by kadet »
Where I cut the holes to access the the bolts I took the opportunity to install some cockpit lights to cover the up the holes 8)
Estate Sail
Post by Estate Sail »
I installed a set of BWY seats a couple of years ago. I found it to be fairly easy. Bolt on to the lifeline stanchions first and make sure seats are level with boat before you attach the small rod support and main support. The only critical area is where you drill the large hole for access to the aft mount bolts. You may have to pick out some flotation foam to get to the back. Get a hemostat to help to get the washers and nuts on the bolts. Seal all contacts with the boat. when you cut the lifelines you will need to swag the attachment points. Harbor freight has a swaging tool (looks like bolt cutters) that works well.
bwygirl
Post by bwygirl »
Feel free to give us a call! Happy to help you get the seats installed. BWY 206 282-4261 line 1
green
Post by green »
I'm on the hunt for anyone who might have filmed their install. Any leads?
1st Sail
Post by 1st Sail »
Once you have the seat in hands the rest is somewhat obvious as you will align the seat rail to the rear stanchion. From that point it is a matter of leveling the seat and marking the location of the lower inside mounting plate of the seat. Note: you may have to bend the stanchion in order to level the seat. I spoke to Todd @ BWY. The stanchion deck mount fiberglass is very strong in those areas and therefore will not stress the deck when you adjust. I tried to determine if the seats were trued when jig welded. I decided it was more trouble that what it was worth to build a jig to check the alignment of the seat tubing. In the end I just bent the stanchion back to vertical approximately 1in.
:macm:
OverEasy
Post by OverEasy »
Kinda envious of you Mac26M owners having the option of installing those nice stern rail seats!🥺
There just doesn’t seem to be a nice way to do something similar on our Mac26X 😔
It’s just a really neat feature❣️
Best Regards
Over Easy 😎😎🐩🐈
pitchpolehobie
Post by pitchpolehobie »
OverEasy wrote: Tue Sep 20, 2022 7:52 am Kinda envious of you Mac26M owners having the option of installing those nice stern rail seats!🥺
Best Regards
Over Easy 😎😎🐩🐈
I was just thinking the same. If bwyachts made them I might splurge. I don't think ID pay 1500 for a pair though.
2002 MacGregor 26X: Remedium
Tohatsu 25HP
kingtoros
Post by kingtoros »
pitchpolehobie wrote: Tue Sep 20, 2022 8:00 am I was just thinking the same. If bwyachts made them I might splurge. I don't think ID pay 1500 for a pair though.
Worth every penny, and I bought this year after the price increase (like everything increased this year, not just our boat parts). Still worth it
Best seat in the house, I now yield the helm willingly to perch up there
Best Regards
Over Easy 😎😎🐩🐈
I never knew BWY didn't make them for the X model. Seems like there ought to be a way to mount them on an X.
Yes, worth every penny and I can't imagine the boat without them. They also make me feel more secure in the cockpit as it creates a "fence" and encloses the cockpit with rails at the lifeline height.
Russ wrote: Thu Sep 22, 2022 6:16 am
Best Regards
Over Easy 😎😎🐩🐈
FYI Their,s a few :macx: owner,s on this site who fabricated their own & installed themselfs
green
Post by green »
green wrote: Mon Sep 19, 2022 9:27 am I'm on the hunt for anyone who might have filmed their install. Any leads?
Filmed my own install.
green wrote: Tue Jul 18, 2023 9:41 am
The next step is placing your stern rail project in the Mods section. You made it very clear for anyone viewing.
