Highlander wrote:I use "Kilt farts" because they r cheaper
And based on experience with the chili in the gazebo at last year's MMOR, plentiful.
Tony - make sure you use RG-58U (standard, -6.5dB/100 ft) or RG-8X (better, -4.7dB/100 ft). Either one is 50 ohm, which is different than other applications, like TV. PL-259 male connector for each end, and you can join two PL-259's together with a PL-258 double-female between them (that's how my deck connection is made). Gold doesn't corrode, so gold plating is probably a good idea, especially in a salt environment.
Length would be 27 ft for the mast (plus a foot or two), and (guessing) about another 15 ft to get to the area aft the galley. So call it 50 ft, and if you get factory ends, you'll have a nice, molded, sealed connector for the top of the mast, and another for the deck area where the coax dives into the deck. You'll have to put your own ends on in two places, of course. There are no-solder connections, but I'd opt for the soldered types, to reduce the risk of corrosion issue. Heat shrink (with internal adhesive), or coax-seal tape, which is NOT electrical tape. This is the stuff the pros use for sealing plugs to coax, and it will seal to itself and be water tight and weather resistant, unlike electrical tape which just comes apart after a short while in the weather.
https://www.amazon.com/Universal-Electr ... B0002ZPINC
And keep the cable as short as you reasonably can. There is signal loss in any coax, and the shorter it is, the less there is.
Another option, by the way, is to use either the 3dB gain 3-foot base loaded whip, or a 4.5dB 4 ft whip, or a 6dB 8 ft whip, mounted to the stern. You lose the distance advantage of height, but you shorten the cable a lot, and you don't have to break the connection to unstep the mast. My boat had one on the stern at one point, based on the skinny cheap coax coming out of a clamshell on the starboard stern coaming that terminates at the radio. They probably had it for cruising the Erie Canal (no mast), as everyone with a trailer boat up here does at some point.
But my preference is for a 3dB base-loaded whip at the top of the mast, for the range (even with cable losses, the signal will still reach the more distant horizon), and because it's cleaner up there. And the 3dB has a wider vertical azimuth pattern compared to the 6dB fiberglass units, so it's more effective when heeled, which is precisely why they make them.
