Full battens?
- Neo
Full battens?
Hi All,
I went for a sail in friends Magnum 28 on Sunday .... I wouldn't swap mine for theirs but I did like the look of the Full Batten main sail which was not bolt-roped to the boom (loose foot?).....Is that something we can do on a Mac .... or not?
All the best.
Neo
All the best.
Neo
- Sumner
Re: Full battens?
That's what I have and have been very happy with but only have the original blown out sails to compare with. More about the main and Genoa and where I got them here....
http://purplesagetradingpost.com/sumner ... ng-23.html
Sumner
The MacGregor 26-S
The Endeavour 37
Mac-Venture Links
Re: Full battens?
I know Judy B can supply full battens on a main. Batten type (full or partial) is just one of many options.
http://www.hydesailsdirect.com/Macgrego ... /11726.htm
Wrong model boat. Here's the M.
http://www.hydesailsdirect.com/Macgrego ... /11723.htm
- sailboatmike
Re: Full battens?
Fully battened will hold its shape better in lighter winds.
As for the foot, there is debate over which is better, seems there is 3 sorts, normal bolt rope to the boom, bolt rope to the boom with a flap (this was to get around JOG rules which disallowed lose footed mains and of course lose footed,
The flap or the lose foot allows you to open out the bottom of the main in lighter winds or so I have read.
Im sure there are better people on here to explain than I around the place
- kadet
Re: Full battens?
https://goo.gl/photos/TAZ6xYgDgjNK8hsR7
This is my loose foot full battened main on my
Does it perform better than the stock Doyle? Maybe.
Is the sail shape better with full battens? Probably.
What do I like about it, it is easier to handle and the full battens help keep the sail in the lazy jacks and are less like to jam in them when I raise the sail
Re: Full battens?
I have a Tattoo 26 which came with a fully batten mainsail & rotating mast. My previous boat was a NACRA cat with a similar rig and sails. The battens enable the mainsail to have more surface area in the air with the same mast. The Tattoo mainsail is patterned after racing boats like the vendee globe boats. I do not have any delusions about racing my 26 with my kids, but it looks pretty cool and I am getting better performance and handling out of the boat than the other guys on the water.
Re: Full battens?
I had this discussion with the sailmaker when I had my sail made. Doyle in Salem MA. This sail was designed as a performance sail with maximum roach. His statement was "a sail that size only needs one full batten on the top." A sailboat with a back stay, full roach is still not that much. Now you X or M's without a back stay (don't remember what one). If you had a flat head with a ton of roach you could probably benefit with more than one full batten. I did go with loose foot.
- yukonbob
Re: Full battens?
Full battens
Pro's - better shape/profile in lighter winds, easier reefing and flaking, less flogging, longer sail life
Con's - harder to depower in heavier winds, more likely to jam raising and lowering, more weight aloft, harder to shape without telltales, *more weight aloft, slightly more expsnsive
*This is insignificant IMO, but someone will chime in about it. Heavier cloth would be more of a concern.
Loose footed allows you to get better shape when adjusting your outhaul in lighter winds.
It's also good to know that it doesn't have to be all or none either and you can go 3/4, 1/2 whatever. You should be shopping for sail for where and what conditions you're sailing...
- Neo
Re: Full battens?
Good point yukonbob and thanks for the feedback gents.yukonbob wrote:It's also good to know that it doesn't have to be all or none either and you can go 3/4, 1/2 whatever. You should be shopping for sail for where and what conditions you're sailing...
Kadet sails in similar conditions to myself so I'll see if i can follow his lead
All the best.
Neo
- kadet
Re: Full battens?
I wouldn't follow my lead I am a pretty lazy, laid back kind of sailerNeo wrote:...
Kadet sails in similar conditions to myself so I'll see if i can follow his lead![]()
All the best.
Neo
https://goo.gl/photos/hfSj2TYHpsbT7Zn87
- Neo
Re: Full battens?
Nout betterkadet wrote:I wouldn't follow my lead I am a pretty lazy, laid back kind of sailer
Looks like I'll be opting for 2 Full top battens and 2 Partial lower battens.... Will see how I go
Sumner, could you please check that link?Sumner wrote:More about the main and Genoa and where I got them here.... http://1fatgmc.com/boat/mac-1/2015%20Ba ... Fowl-2.jpg
- Sumner
Re: Full battens?
Sorry about that, this should work....Neo wrote:....Sumner, could you please check that link?
... and I fixed the other post,
Sumner
The MacGregor 26-S
The Endeavour 37
Mac-Venture Links
- Neo
Re: Full battens?
Hi Summer,
Great photos....
Is that a loose foot?
Whats inside your boom track that I'm assuming your top-lift is attached to?
Great photos....
