26 m with a 90 hp?
Re: 26 m with a 90 hp?
Hi,
I have a problem to legalize a enigne with more than 38 kW (50 hp) which is specified in the examination report (declaration of conformity) coming with my 26m.
I like to use the boat on Lake Constance (Bodensee).
Does anyone who uses a bigger engine have a matching declaration of conformity?
Thanks for your reply,
Rainer
Rainer
Rainer..I don't think a certificate of compliance was ever issued for a motor larger than 60 HP
- kurz
Hallo Rainer
Es spielt wohl noch eine grosse Rolle ob Bodensee-Schweiz oder Bodensee Deutschland.
Ganz locker wird es wohl nicht gehen, weil beide Länder erst mal auf CE setzen serden. Nach Gefühl könnte aber die Zulassung in D mit grösserem Motor wohl einfacher sein wie in CH.
Besseren Rat kriegst du aber im booteforum.de
Gib Bescheid wie es ausgeht!
- sailboatmike
As far s I know 50Hp for the X (or 60 for the M) was only a recommendation, my early X has no tag on it giving maximum rating for the motor
- kurz
I think he talks about Bodensee in Germany/Switzerland...
So there you have the CE - and there you can see the max 60HP for ther
Thanks for your replies.
My CE from IMCI in Brussels is with only 38 kW rated power.
On bwyachts I found a specification and engine recommendations for 70 hp:
http://www.bwyachts.com/26mspecs.html
http://www.bwyachts.com/engines.html
So I send a email to the IMCI what about 70 hp (52 kW). I am waiting for their reply.
Rainer
Rainer
- yukonbob
The catch with installation of a 70hp is that the installation is exclusive to BWY having designed the installation in conjunction with the manufacturer.
- kurz
very strange you have a 50HP paper for the
If you need paper for the 26m in German you can contact me on mail.
Have to look but I thing at least there is th 60hp information.
There are huge differences between regulations in countries. In the USA, the Macs are of a size where there is no regulation of engine size, for instance.
- sailboatmike
Dont get me started with National laws, here in Australia we have state boating laws, believe me that makes it a hodge podge of rules that often conflict with each other in relation to licencing and if the boat needs registering
If u watch the sales video Roger say,s he recommends the 50hp power as a max because u can always pull start a 50hp if ur battery goes dead !!!
I do not believe there is any mention in the vid or in the boat
manual that says u must not exceed 50hp
yep I just read the manual I do not see any mention of 50hp max
Just sayin that,s all
- kurz
sorry Highlander, we are here in Europa, so we have CE-Regulations. So in any CE you will find max HP. And in the
- CE Roger says 60HP.
U know a lot of the newer electronic engines the HP is controlled by computer programming my 75hp Merc 4 stroke is the same motor as the 90hp Merc & the 115HP Merc all spec,s block & gear case r the same !!kurz wrote:sorry Highlander, we are here in Europa, so we have CE-Regulations. So in any CE you will find max HP. And in the- CE Roger says 60HP.
Some people have been know to have turned the engines up !! & on some engine,s it,s only an air intake dam restricting air flow reducing HP
my 75HP Merc has more torq than the 90-115HP engines so it is better suited for the heavy & more rounded hull of the
So it is not always just about increasing HP depending on hull shape & boat design & weight , so sometimes more "Torq" is desirable & will give u better results
Just sayin that,s All
Hi all,
I stopped my effort to legalize a motor with more than 50 hp.
I got a offer of 2.500 EUR for a post construction assessment (PCA). But for the test drive the motor needs to be at the boat... It was not sure that my
would really pass this test.
So I did the easy way:
Yamaha sells their F 70 AETL as a F 40 GETL in Italy (40 hp limit, if you have no driving licence). There is just a plate to remove in the intake. No need to change or reprogramming the ECU. Check the bills of material if you don´t believe me.
Bodenseezulassung was no problem.
I am happy,
Rainer
I am happy,
Rainer
