Here are a few shots of the before:
Good deal on the motor! That was worth the price itself.taime1 wrote: Not sure if I mentioned this, but the boat came with a pretty new Nissan 9.8 long shaft motor. I changed the oils and plugs and it runs nicely. That was an awesome surprise because it wasn't listed as part of the deal.
The only thing I am a little leery on is the wiring, I haven't gone through it, nor have I connected a battery yet.
taime1 wrote:The motor is quite nice. Here are a couple of pictures. Not sure why Tinypic flipped them on their side...
I do wish it had forward/reverse selection on the tiller handle, but I can't really complain. I hacen't hooked it up to a battery, but it appears to have electric start and charging, which is nice.
I do have one engine-related fix to do. I need to figure out what sort of cover I should put on the hole from the laz to the engine well that is used for the fuel line:
I think I can just get a larger clam type cover and that should keep the water out. The PO has a small one, loosely attached only at the top, but I didn't like it.
