Hi everyone I am new to forums and new to owning a 2001
I will be hauling boat to San Carlos Mexico but first think I should apply some kind of bottom finish to protect the hull. As it is the haul looks really clean, appears to have had NOTHING on it. It does have really tiny bumps like dimples everywhere (I do not believe blisters). I would also drop the center board and paint it as well. I have read a lot of posts and still don't know what process I should follow. Wash soap water, dewax, clean with alcohol wipe, sand (100grit) wipe with alcohol OR use Interlux no sand primer, then apply 2 0R 4 coats Interlux barrier coat OR 2 coats of Pettit protect expoxy primer, then 2 coats of Interlux Bottom Kote or 2 coats of Trinida Anti Fouling paint.
Please help. I inquired on the cost of getting this done in Mexico and it was well over 75000.00 pesos ($5700.00 cdn) so I have read how many of you have done the work yourselves well still on the trailer. I will build the supports I require to get access to hull (plan to do it safe). Will the trailer lifting procedure work with a tandem axle?
The produsts I have listed seem to be the easiest to use the West System sames a little over kill. What would you recommend?
PLEASE HELP....... I want to get started.
