I thought up this mod to not only get around that, but to provide a grab-rail for my Admiral (and others) who needed it, and also averting breaking the table when things went wrong. The only thing I did was to drill a hole (plug-able) through the surface and thusly re-locating the original leg position somewhat forward by six inches or so.
Under clearance is in a happy place:
http://i1121.photobucket.com/albums/l52 ... hsflns.jpg
I used my redundant rudder link-bar cut down and fitted with a threaded slug) as the grab rail.
http://i1121.photobucket.com/albums/l52 ... jzhrwv.jpg
http://i1121.photobucket.com/albums/l52 ... gkkoog.jpg
Attached to an upsized SS machine screw located in the sliding cabin hatch topside rail
http://i1121.photobucket.com/albums/l52 ... scigex.jpg
The nut attaching the original screw will be located behind the removable plug in the ceiling above the table. Make sure you use washers and nylocks on both sides, as well as some 3M type compound to seal things up again,
This is much more robust than the factory effort and the table is not being prevented from its alternate purpose of turning into an extra bed.
Ross
