Chinook wrote:The 26X rudders have holes in the brackets and rudders, which are designed to have bolts placed in them when the boat is being trailered. These bolts prevent the rudders from falling when the boat is being towed. It would be a good idea to locate those holes and pick up a pair of stainless bolts and nylon bushing lock nuts, to prevent this problem from happening again.
I use one of my two stern dock lines, in a soft loop from one stern cleat, around the rudders, then terminated on the other stern cleat. That's in addition to the usual rudder hoist lines, cleated on their own little rudder cleats.
My rudders are the longer, later model type, which don't have holes for bolts, though I could drill them I suppose. But the dock line loop makes a nice backup for the rudder hoist lines and cleats.
The other stern dock line, by the way, is used to stabilize the mast at the crutch, so it doesn't wobble and load the helm while trailering. One winch, through the genoa block, a couple of turns around the mast at the crutch, through the other genoa block, then tied off at the other winch, with some preload (push the mast sideways, toward the first end tied off, then take the slack out) so the mast is nice and snug when bouncing down the road.
Using the dock lines also means they're right where I need them when I launch.
