I understand that these older tanks (Tempo) may not be available any longer, and the new ones might not fit.
We had them installed in both aft sections under the cockpit seats.
Any advice would be welcome.
Darry
Great point jstyers,jstyers wrote:My concern would be that if you make it difficult to remove the tanks you may end up with a damaged boat AND stolen tanks.
Hey dlandersson,dlandersson wrote:Okay, I'm a little lost here.![]()
Your slip does not have security?![]()
If so, why not use 6 gallon tanks - and take them with you. No tanks, no can steal. Then when you go sailing, simply carry them to the boat.
RobertB,RobertB wrote:Sounds like reasonable security - good chance it was by someone with access to the yard. Have you looked around at the other boats there to see if they have "new" fuel tanks? Recommend painting the tanks to make them easy to identify.
