I try not to revive an older thread on principle, but I was just trolling through some of the past conversations when I stumbled on this jewel and blew coffee out my nose.mastreb wrote:5) Because it's light, it won't make it through a tack on momentum. You must backwind the jib to get the boat across the wind, and then tack the jib once you've arrived on your new heading. With practice this can be done quickly, but you do lose a bit more momentum because you can't tack while turning.
A Mac X sails fine and does not have said problem. If you are having issues tacking, then you are probably doing something wrong. First - Take the person who taught you to sail out back and beat the snot out of them. Then try doing it correctly.
When tacking the standard command to the crew is "Helm's A-Lee". What this signifies is that the helmsman has THROWN the helm HARD over to the leeward side of the boat. What that means on a boat with a wheel helm is that you spin that wheel. Leave the jib sheets lashed as they are until they start to back on their own, then just release the cleat. DO NOT force the issue by tightening them in on the other side too soon, doing so will slow your progress and could stall your tack. The jib will first back and then luff as it crosses the centerline. Only tighten the sheets after the jib has crossed the centerline of the boat on it's own (if your sailing with a genoa, this means the bulk of the sail. In light air a genoa might need some assistance to clear obstructions, but wait until it needs it). Then they will fill and you're off on the new course. If you are tacking close hauled to close hauled (most frequent case), nothing needs to be done with your main. Just watch your apparent wind to make sure you don't turn too far. When done correctly there should be very little loss of speed and momentum (even on a Mac). The key is to turn fast and when you reach the other tack, reverse rudder quickly to stop your swing.
