Had some issues, but I got the mast up.
But the rotating mast seem to be almost impossible to rotate with my hand. Very sticky.
It appears that all the rigging and weight of the jib, sail and boom is loading up the rotating joint quite a bit.
I am not sure if it'll rotate with the force of wind..... Is it supposed to be really sticky (firm) to rotate? or is it supposed to rotate freely?
There are 3 washers sandwiched in between the mast base and bracket. Should there a thrust roller bearing or something?
I don't know what it's supposed to be like..
Thanks in advance.
