I've been looking at BWY's dodger setup for the 26m since I bought the boat and still can't figure if I need it?
In open water, there can be a lot of spray on any boat (plus for a wide/deep dodger)...but I usually sail solo and just put in the hatchboard and close the hatch! If I do go below, it's very brief...and I can step over the hatchboard, open/close the hatch (quickly)...get what I need...and repeat the opposite with a few towels laid over the sensitive areas below (batteries, electronics, etc) to absorb spray/mist as I transit the opening.
If I have the dodger, no hatchboard and hatch open or closed...I'm still getting salt mist/spray below...into the power center of the boat...nogo.
If I have dodger with doors, I now can't duck below as fast (unzip time) or risk leaving them open to the elements (as if I didn't have them and back to towels for protection)!
If family is aboard and I am in conditions to need a dodger (10+ hours crossing of open water), they won't be likely to stay below to combat possibility of seasickness...in which case why not seal below with hatch and hatchboard!
At anchor in FL rain (heavy)...dodger and doors could be nice to stand and look around while dry...until the sun intensity causes them to leak over the years...and again, why not the hatchboard and hatch closed...look out the windows instead?
What am I missing from those of you who have the above setups (dodger and dodger plus doors)(not full cockpit enclosure...too hot in FL)??
On bigger boats with side gunnel access to the foredeck, a dodger is necessary to keep water/bow spray/mist out from down below/cockpit...but on the 26m, if you did that type of dodger...no access to the foredeck or water/mist/spray below??
Thanks for your help and advice in advance!
Fair winds,
David
PS...here are the links to the two setups I am contemplating:
Dodger: http://bwyachts.com/web%20catalog%20312 ... dodger.htm
Dodger with doors: http://bwyachts.com/web%20catalog%20312 ... _doors.htm
