It's got a 9-gallon capacity and can be found for about $400 US, plus shipping. It seems like a pretty good fit for my
I've seen a posting from a
- My current fresh water tank is only 7.5 gallons, should I put in a bigger one to accommodate the additional water usage?
- Is 9-gallons truly sufficient for 4 to 5 days (with careful use)? Then again, I could always connect a 2nd holding tank via macerator pump if capacity is an issue.
- Is it a bad idea to connect a single water source to sinks and toilet?
- Is this worth the $ for what is essentially a glorified potti?
I've looked at the composting heads, but don't want to got that route due to the dealing with liquids part.
I also looked at a Jabsco manual flush, but the fellow at the local store seemed to think they need a through-hull for the intake water and may use more water per use.
Any thoughts or suggestions are appreciated.
