I wanted to share my recent find and work in progress. I managed to aquire this V17 for free from a lovely couple on craigslist. The boat sat unused for at least 10 years and for 4 or more years without cover. The hull, rig, sails, and deck hardware are all in remarkably good shape. Those are in sharp counterpoint to the interior which sat full of rainwater for who knows how long. The boat seems to have additional trim that I haven't seen in photos of other restorations, all dark laminate. Everything lower is shot but the trim around the deck joint appears solid enough. As of last night I've pulled out everything that's easy to get to from the interior. I still have to cut out the ends of the quarterbirths which are under the cockpit.
The keel winch was rusted through also. I have ordered a new zinc coated Dutton Lainson 800lb brake winch from Amazon. ($76) I'm replacing the keel winch, cable and bolt also. The keel on this one also appears to be entirely cast iron so farl. I've begun scraping and chipping off the paint and rusted areas. I'm planning now to just hit it with rustoleum rust reformer and a few coats of black enamel to get it going. I'm planning to pull the pivot bolt for inspection and drop the keel this weekend.
For the interior, I'm going to focus on replacing the structural pieces for now. Those being the cross bracing at the centerboard box and the support for the mast. Unfortunately as I removed the rotten quarterbirth plywood I discovered the hull stiffeners that run underneath them are entirely soft. Looks like the fiberglass is good but the wood is rotten inside. I'm wondering if I can split those open, pull out the rot and replace with new wood then fiberglass tape and epoxy over the top. Has anyone else had to do this?
I hope to have the boat in the water within the month. I'd appreciate any comments for feeback from anyone who's done a restoration on one of these.
Thanks!
Steven
How I found her:
Album of all the current photos here:
https://www.flickr.com/photos/127633153 ... 701364245/
