kadet wrote:Yes I was performing a regular hove to with almost a fully furled head sail just enough out to counter the double reefed main (I only have 2 reefs)
But it was the free board that is the issue. I don't care how you heave to in these boats the hull is enough to sail these boast in any strong wind.
Without a full keel and more weight these boats are just not going to be stable for any significant time without power. They are just too light and too fat and I concluded very quickly after heavy to that if you have any sail up and you get hit by a micro burst you will be in real trouble.
I don't feel comfortable with any sail up in 60mph winds gusting higher and lightning bouncing around. I also don't feel comfortable on deck. However, if so, pfd and tethered to something is a must.
These boats have so much windage, I bet with 60mph winds the boat would blow away at 5+knots with the wind, probably more. You better have plenty of water between you and shore, which I assume is why you are not in a safe mooring to begin with.
All boats I've been caught in T-storms in faired best pointed into the wind (and waves). For that you'll need to be motoring for steerage or something off the bow to hold you there. A drogue (yea we all have one of those right) or as IX mentioned, maybe make one of an anchor and lots of line. Who knows, it might even catch the bottom and slow you down. Just to keep the bow pointed to the weather.
I spent a long night in a protected cove with 50mph gusts with the Mac on hook. I was a couple hundred yards from the lee shore and the boat was a bucking bronco all night. All that windage.
If you are going to heave to, better practice and know what you are doing. Better have everything secured REALLY well. The most prudent thing is to be aware of weather and avoid it. With modern weather apps, this is easy to do.
